Ball joint help...no really help...
2.3K views 12 replies 7 participants last post by  bpost
#1 ·
So I think i have figured out its my lower ball joint is making the sqeaking on my 2000 xtetra..
Can anyone tell me or guve me a quick run through on whats involved in replacing it..im broker than broke..so i wanna just try n replace the lower..:lesen-big:
#3 ·
Ok well thx for that post...can anyone answer a stupid question..this is makin noise but how long can i leave it..like is this something that can just break...or will it just stay noisey...i think saving n getting a shop maybe a better idea..although i can swap engines..trannies...etc etc..i think i lack the patenice..
#4 ·
You can run with a bad ball joint for a while if you dont mind the noise or steering slop, but you could probably get the whole thing done in 2-3 hours if you have a ball joint press ( [ame]http://www.amazon.com/OTC-6297-Ball-Joint-Separator/dp/B0015PN010/ref=sr_1_9?s=automotive&ie=UTF8&qid=1365731365&sr=1-9&keywords=ball+joint+press[/ame] ) and 1 7/8" socket.
#6 ·
Just replaced both of mine 2 days ago. I pulled the steering knuckle as well cleaned and repack the wheel bearings at the same time. Make sure you have new seals, the entire job took me about 6 hours, you do not need a ball joint press these ball joints are bolt in not pressed in. 1 7/8" socket with a large breaker bar for the lower. Then hammer it out and put in your new one. The ball joint part number in Moog is K80591. The outer seal SKF part # is 22230, Inner (seal at knuckle/cv shaft) part #19689- this one may not need to be replaced. Otherwise just basic socket/ wrench set.
#7 ·
^They're pressed in stock. You must have aftermarket control arms. Unless you're talking about the lowers... but you still have the uppers to deal with.
The ball joint press is a very good idea. I got mine at NAPA (they can order it in) for less than that Amazon one.
#9 ·
This whole post is about lowers!
You have to take the upper ball joint out of the spindle to get at the lower. That's what the tool k-man suggested is for.
#12 ·
i'll tell you from personal experience. DO NOT NEGLECT OLD BALL JOINTS.
I did, and my upper ball joint BROKE going around a corner at like 15mph.
If i wasn't going to my friends house after work, then i would have been on the freeway and probably would have died.
Get that shit done
