tomorrow
1 reading
1.4K views 7 replies 6 participants last post by  mac11
#1 ·
i doing an oil change and maybe seafoam
anythink to look out for with the sea foam also where is the vacume line?
thank you
grant
#2 · (Edited)
Add the prescribed amount to the crankcase oil.
Take the rubber line off attached to the brake booster. Insert a funnel and slowly drizzle a 1/3 can in while the engine is running. Shut it off for 5 minutes.
Dump the rest of the can in the fuel tank.
Start it up and watch your neighbors freak out as a haze of smoke engulfs their house. You'll find out if you have cracked exhaust manifolds or not.
Change the oil after your done as so your removing any deposits that may have made it's way into the oil.
#3 ·
thanks silver someone told me that its sapose to stall the vehicle out
did you feel a difference after you did it
anything else i should do tomorrow
#4 ·
I don't think it's supposed to stall the engine, what with the hose being so small, it's hard not to. It took a bit of patience, I found.
#6 ·
when i use seafoam i pour in around half of the bottle and shut it off for 45 min then i start it and let it burn off all the residue.... and no it shouldnt stall the motor unless you are injecting it in way to fast...
#8 ·
you need to regulate the uptake of the seafoam so the vehicle does not stall.
