I was wondering if anyone has put a VG33E in an SC xterra/frontier (While keeping the SC). The reason I ask is my rod bearing is going out and the most economical route to fixing it is to find a rebuilt VG33E and putting it in with the heads, SC, intake and plenum from my VG33ER motor plus all the accessories.
I know the VG33E run a higher compression I believe its 8.9:1 compared to the 8.5:1 in the ER motor. To me 8.9:1 is still low enough to run a SC. Has anyone successfully done this?
I would like to avoid rebuilding my current bottom end as it will cost more and take a lot more time then just buying a rebuilt VG33E short block.
thank you guys!
thank you guys!
