Tire pressure question
3.1K views 5 replies 6 participants last post by  samboi
That might be the Max Cold PSI. You don't want to run it at that! You want to use something at or close to the recommended pressure for your vehicle. 26PSI I believe was normal for first gen Xterras with 265's from the factory. I usually went a little higher, around 29.
