2003 Timing Belt Parts List
978 views 13 replies 3 participants last post by  DeltaX
#1 ·
Is there a list of parts that are needed for 2003 3.3 L timing belt change, including hoses and stuff needing to be changed at that time? I probably will get at Rock Auto.
#2 ·
If you have the FSM (it's free to download, if not), it tells you all the steps. I suppose you could make a list.
When I did my 2001, and then later my 2004, I ordered a kit from RA. The 2001 needed the harmonic balancer replaced, so when I did the 2004 I just bought it outright.
For the air hoses, I took mine down to the local auto parts and bought hose that was about the size I needed. For heater and radiator hoses, they're still available most places.
While doing the 2004, I lost one of the 2 little pieces (grommet-front cover) that goes between the cover and the engine. I also noticed how the rubber grommets on the bolts were cracking. I ordered this kit from RA as well:
Measurement:
Before and after:
Finished the t-belt, still reassembling:
Reactions: dezurtrat
#9 ·
Thanks a bunch. I thought I'd replied to everyone but haven't posted much and not used to the site yet. Your info is appreciated very much. I hope to do the job as weather permits. My shop is not heatd. I'll get everything ordered soon.
Is there any brand at RA that's the best?
#3 ·
You might also benefit from knowing what bolt lengths go where, and whether you're missing any, by using this info:
#4 ·
Z1 Motorsport sells a kit for the timing belt including a water pump. I’m sure the kit may be available through the dealership or elsewhere.
#5 ·
Thanks! All your info is appreciated! I want to have all the parts needed before I start. My only spare vehicle is a 2005 VTX that's is not as dependable as it used to be. I don't look forward to the job but I do all my work, on everything. Thanks again and I have the manual on hard drive somewhere and will read over it also. I know there's other parts that may need replacing while I'm at it. Thanks a bunch for your reply!!
#7 ·
Thanks a lot! All your info is of great help. I'm preparing to order maybe next week and will study up on it before hand. I know there are other items I need not in the kit. I'd like all the parts before I start. This 2003 Xterra has about 300,000 on it soon and the engine code light has never be out since I bought it years a go, but it's still running. Thanks a bunch!!
#8 ·
I did do a how to write up on changing the timing belt which is on this site. There may be others also. I can find a link if you like. In my defense it was years ago.
#11 ·
