Hey guys,
So last night we replaced the Rad, water pump, timing belt and thermostat on my '02 Xterra SE/SC. We filled the new rad up with about 8L of coolant and ran the truck to try and bleed the system. Now, we didn't think to open the bleed bolt on the intake because apparently we lack common sense. However, we did the same service on my old R50 Pathfinder (VG33E) and just ran the truck with the rad cap off to bleed the system. On the R50 once the thermostat opened it started to burp all the air out the rad cap, and we filled as needed. Not so with my Xterra apparently. There was never any burping of air out the rad cap. In fact, after almost 20 minutes at idle, and a few laps around the block (maybe 5km of driving) the new thermostat never opened, the lower rad hose remained stone cold. The temp gauge never went above half, but still. Over 20 minutes of idle plus some driving, we figured the thermostat should open, no?
We tried the same thing again with the bleed valve open, however it still yielded no results. I'm more confused though about the thermostat not opening, and the truck not overheating.
Any ideas? Is there a different way to bleed the system?
