Hi. My name is Robert. I'm from Poland.
I am a happy owner of Nissan Xterra 3.3 v6 supercharged 2002 with manual transmission.
Unfortunately, I have a problem with it. After the engine started , it runs for about 10 - 15 minutes and off. After checking what happened it turned out that there is no spark at plugs.
After pulling back and plugged the plug from the ignition distributor engine start again..
After 5 minutes off again. I pull and insert a plug from the ignition distributor and start again. After a few minutes engin off. Crankshaft position sensor is new also distributor, wires and plugs. Any tips or advice would be appreciated!
Probably needs a new distributor...make sure you match up models, they are really picky...make sure the new one has the same one or it might not run properly
Darin
01 Xterra SE 4x4
COMING SOON:
Wish list:
Distributor is new.
Yesterday I discovered a defective MAF plug . I need a picture of MAF plug with the colors of the wires. I will be very grateful.
