1 - 2 of 2 Posts
Hi,
I have a xterra 2002 SE with factory Steering Wheel Control Interface. I removed the stock radio and bought:
Jensen VX7020
Metra Axxess ASWC-1 Universal Steering Wheel Control Interface
Metra 70-7551
I tried to install ASWC-1.
The interfact of Xterra does not look like it will connect to the adapter of ASWC-1.
I attached a picture with one harness marked with red arrow. Can you tell me that is for Steering Wheel Control? If so, how do I connect it to ASWC-1?
Thanks
Old thread, but figured I'd answer: here are the Xterra specific instructions: https://metradealer.com/files/aswc/ASWC-1_INST_870.pdf
That is the correct car plug. There should be two wires in there: yellow/black wire and a yellow/red wire - these are the car wires. You will connect those to the ASWC black, white/green, and grey/red wires. Specifically:
  • ASWC Red wire connect to radio wiring harness red wire
  • ASWC White/Green and Black connect to car's yellow/red, and all of these should then go to chassis ground. Basically join the 3 wires together to another wire which you will run to some metal part on the car
  • ASWC Grey/Red wire connect to car's Yellow/Black wire
1 - 2 of 2 Posts
