1 - 4 of 4 Posts
So I have a 2002 Xterra and this morning I got inside and tried to turn on my vehicle lights, Radio, and everything come on. However, the motor won't start. Anyone know what's wrong
2003 SE 4x4 V6 100k miles
So what is happening when you turn the key? Is it cranking but not starting? Just making a clicking noise? Nothing?
Troubleshoot electrical connections to the starter. Use the Factory Service Manuals which you can find on here to find the fuse, relay, and also visually inspect any wires going to it. Make sure the battery terminal connections don’t have issues such as corrosion. You can potentially hit on the starter with something solid to free up something that is binding up in there causing it to not start. Not too hard to get to from under the vehicle on the passengers side
1 - 4 of 4 Posts
