1 - 13 of 13 Posts
I have a 06, X, out of warranty (47K) and when I reach 60MPH I get a high pitch whine from the rear end area, by 66mph its nearly gone and when I reach 70, all's quiet. I have replaced the tires so I know its not that. Its not real loud, but I know its there and it can be annoying ....any ideas??
· Premium Member
Welcome to Gen II Xterras. Seems like a common complaint. Try switching to synthetic and see if it quiets down. I'm on my second rear axle (OR model) and they both did it from day one. Helped when I went to synthetic gear lube.
· Premium Member
It's common on gen II xterras ('05 - '08). I have seen several posts about the whine at about 60 -65 mph and quiet at the other speeds. I have no idea why. And yes, mine still whines at around 65 mph but much quieter since I changed to Mobil 1 synthetic. The OR models require synthetic gear lube in the rear axle but the Mobil 1 helped.
· Premium Member
Yea, it's frustrating and damn annoying but I've learned to let it go as so many people have said the same thing.
· Premium Member
lol...sorry dude!
Powertrain Warranty is good for 60K miles. If it ends up being a problem with your rear diff, you are still covered for another 13K miles.
im new here.. i have an 06 X 4x4 6spd recently been to the dealership many times for noises.. i had my rear axle assy. replaced @ 29K miles due to severe whining.. they have this issue w/titans/armada's/pathfinders and frontiers also.. my new rearend has less than 5k mi's on it and its beginning to whine also.. they say they cant hear it and that it sounds normal which is BS .. no gearset, set-up properly makes any noise whatso ever. sorry im venting as i have many problems w/my 06 X w/34K miles on it and the dealership cant hear a single problem other than normal noises
1 - 13 of 13 Posts
