Hi All. I have a 2008 Off Road and am replacing hubs and ball joints. There are 4 - M12 X 35 bolts that hold the wheel bearing hub assembly to the knuckle. These bolts are supposed to be replaced when the hub is replaced but I can't a source. I can't even find a Nissan parts diagram that corresponds to get a parts number from. Any help would be appreciated. Thanks.
03 XE A/T, SC coming soon
I don’t believe these are one time use parts. Usually they’re listing the lug studs as one time use, don’t know I’ve ever seen the mounting bolts like that. I’ve installed easily dozens of these, never replaced those bolts
I talked with 2 Nissan dealerships - neither has stock and they both indicated that they reuse them when replacing a hub assembly. I am waiting for 1 to arrive - that is all I need at this point. Thanks.
