1 - 20 of 131 Posts
Unlocking Potential
To assist CX members in wheel and tire choices, this thread will be an ongoing (living) reference to what members are running. Please keep posts on topic. NOTE: Wheels must fit the 1st or 2nd Gen Xterra. Please do not post potential buys.
Please provide:
1) Xterra Year and Trim
2) Modifications (SL or BL? Melt Mod?)
3) Wheel Manufacturer and Name
4) Wheel size
5) Back spacing
6) Tire manufacturer
7) Tire Size
8) Photo
Unlocking Potential
Discussion Starter #2
Pro Comp
1) 2007 Off Road
2) 3" SL with melt mod
3) Pro Comp 7189
4) 16x8 (6x4.5)
5) 4" Back spacing (Hubcentric: No, Offset: -12mm)
6) Toyo Open Country M/T
7) 265/75/16
1) 2004 SE S/C
2) 2" body lift, 1.5" suspension lift (PML)
3) Cragar Black D
4) 15 x 8
5) 4.75"
6) Cooper STT
7) 33x12.50x15 (required extensive trimming of front plastics)
Clearance with rear wheel fully stuffed.
1) 2000 SE
2) 2" BL 3"SL
3) Cragar Soft 8
4) 15x8
5) 4" back space
6) Dayton Timberline MT
7) 33" x 12.5", lots trimming of front fenders, removal of mudflaps
1.2000 XE
2. pml
3. cragar soft 8
4. 4.75 BS
5. BFH to fender and removed front peice
6. 32 x 11.5
7. BFG at ko
1) 2005 OFF ROAD
2) 7" suspension lift
3) Pro Comp 6089-6868
4) 16x8
5) 4"
6) Nitto Mud Grappler
7) 315/75/R16
2001 XE
AC UCAs/ Alcan springs w/ AC shackles for about 3.5"
AC 2" BL
Crager Soft 8s
15x8 w/ 4 3/4 BS
Goodyear MTRs w/ Kevlar
33x12.5x15
1) '04 Xterra XE
2) 3" SL & trimming
3) U.S.Wheel 94 Series
4) 16x8"
5) 4"
6) Toyo Open Country AT
7) 265/70R16
Super Moderator
1) 2004 XE
2) 3" suspension life
3) nissan OE
4) 16x7
5) 4"(stock 5.5" + 1.5" spacers
6) goodyear wrangler silent armor
7) 265/75/16
Super Moderator
1-2004 SE/SC
2-3" Calmini front bumpstops removed to make it 3.5", rear Calmini 1.5" lift shackles, Stock leafs mated with Calmini 5" SAS leafs, 2 leafs removed from Calmini Leaf pack, + 2" BL, tires fit fine on the rear, but chose to remove mud flap, tires would fit fine up front with at least a little bit of plastic trimming, but chose to pull the plastics off completely, then chop the fenders, then pulled the fenders later on.
3-Nissan SC rims
4- 17" x 8"
5-5.5"-stock backspacing
6-Pro Comp Mud terrain
7-33/12.5/17
Stock height here
After BL-I also removed all mud flaps and step rails at this time
Next day, I put some 33" tires on
Next, I bought Calmini's 3" SL with Bilstien shocks
trimmed
With leaf the modified leaf pack:
1) 2002 Xterra
2) PML,low profile bump stops
3) Nissan ugly's
4) 16x7
5) 5.5"
6) Wild Country
7) 267/75R16
1) 2000 Xterra XE
2) PML + 2'' BL + Extensive trimming of plastic mud flap
3) Stock Cheapos
4) 15x7
5) 5.5''
6) Nokian Vatiiva MT
7) 33x12.50x15
1- 2002 SE 4x4 supercharged V6 (first generation) (3.3L 6cyl 5M)
2- None yet.
3- Nissan aluminum-alloy wheels
4- 17x8jj / 40 mm (offset)
5- I dont know yet, Im searching which is the Back spacing for my X
6- BF Goodrich Rugged Trail T/A®
7- P265/65R17
Additional info:
( from http://www.bfgoodrichtires.ca/specs/rugged-trail-t-a/1163.html )
Passenger car tire
Section Width: 10.43 in ( 265 mm )
Rim Diameter: 17 in ( 431.8 mm )
Rim Width Range: 7.5 - 9 in
Overall Diameter: 30.7 in ( 776.22 mm )
Sidewall Height: 6.78 in ( 172.21 mm )
Radius: 15.28 in ( 388.11 mm )
Circumference: 96.00 in ( 2438.4 mm )
Revs per Mile at 45 mph: 678.0
Tread Depth (IN/32nds) 10.5
Please provide:
1) 03 se
2) 3" ac sl
3) american racing steels
4)15x8
5) cooper discover stt
6) 32/11.50/15
on crazy flex i rub a littler on the inner well
1) 01'
2) None Yet.
3)Factory Wheel
4)15x7
5) Uniroyal Laredos (crappy)
6)265/70R15
1) 2002 ex s/c
2) pml + 2" bl
3) crager black d
4) 15x8
5) 4.75
6) toyo open country mt
7) 33x12.5x15
1 - 20 of 131 Posts
