This might be a dumb question but Does any one know what the biggest tires I can fit under a 2001 xterra without a lift just stock?
Since a lift doesn't make room for larger tires, except at ride height...it doesn't matter if you have one or not if you are going to off road it where wheel travel is required...the same maximum size will fit.This might be a dumb question but Does any one know what the biggest tires I can fit under a 2001 xterra without a lift just stock?
Yes you could run a 285,as long as you never flex.Just did 3" suspension lift. Stock tires are 265/75r16. I have more clearance between tire and fender well, why can't I go to a 285 tire? Where will it rub? How bad will it rub?
