Hello all,
I was wondering what size ARB fridge/freezer would fit best in the trunk without having to fold the seats? I'd like to get one that wont block out the view in my rear view mirror also. Would the 63 quart unit suffice? I'm open to suggestions.
63 is way too big, most get the 50 quart and that can be mounted on a nice slide for easier access. Great fridges.
Depending on how you use it you may need to run larger gauge wiring to the rear. Stock works ok most times but during times of intense heat/use you can get erroneous low batt warnings from fridge because the stock wiring is on the verge of handling it.
Thanks for your reply! I'll look into the 50 qt units
I'll also keep your advice in mind about the factory gauge wiring issue
