1 - 9 of 9 Posts
Poke around the site, lots of tire discussions. Also how do you feel about the "melt mod "- trimming the plastics behind the front wheels. It gives you more room. I'm not certain but I think 31s are easy to mount.
My first '01 X had 265/75-16 tires on the stock alloy rims. They were BFG K0s (installed by previous owner) and he did slightly trim plastics to fit (not positive if he needed to).
My current '01 X has 245/75-16 tires on the same stock alloy rims. These are Goodyear Duratrac MTs and they fit great... no alterations needed. Fill in the wheel wells nicely.
Cheers!
265 / 75 R 16 for 16 inch rims
32 x 11.50 R 15 for 15 inch rims.
If you go to a 33" tire, you need a 2" body lift.
You may have to trim small amounts of plastic inside the wheel well, but nothing cosmetic or visible. there is just a small rib behind the mud flap that can scrape. Snipping it with pliers or a dremel makes quick work.
hey guys I just got me some 245-75-16 wich are the same OD as OEM size but on 4.5'' of back spacing wheels and it's rubbing a bit on right side (i already remove de long mud flap and cut a bit of the smallest one).
does anyone has an idea about what to check?
Check what? Just cut what it's rubbing into.
hey guys I just joined.. I was wondering if I can see some pictures of your first gen trimmed wheel wells. I cannot find one picture on this site or anywhere for that matter of first gen trimmed plastics im looking to put my 31" falken wildpeaks off my toyota pickup right now they rub somthin fierce. also what tool does the cleanest job of cutting?
1 - 9 of 9 Posts
