Also used a Rain X restoration kit on the headlights this weekend. Not sure how long it will last but for $20 and 45 minutes of work I can do it again in year if needed.
I didn't know these things were so damn heavy!!!! This was a "economy" winch but thing was approx 70lbs!!!! not heavy perse bu trying to squeeze it in there and maneuver the mounting holes was a bitch!Proper 🤙
thanks man! luckily the Hardcore Offroad bumper was pretty fool-proof and already had the holes pre-drilled for the standard hole spacing of most winches. the hardest part was routing the cables through and around the radiator and between the front clip. I may go back with silicone/rubber sleeving since all the power and ground cables look like they may rub during bumpy off-roading and I don't want to short it out in case it eats through the cable sleeve. Thing claims to be 13,000 lbs, and these synthetic ropes claim anywhere from 8000-15000 lb tensile strength. All things considered I seriously hope to ever test their fill capabilities LOLbeautiful, very well done
noticed a lot of people have been adding winches recently. saw an X the other day at the walmart parking lot with a winch installed, didn’t look properly done. looked like two metal arms welded onto the frame of the X, then mounted onto the sides of the winch. stock bumper was still on, but had slits in it to allow the metal arms to pass through. was slightly sagging and was off centered
I did the same but i put a blue 168 bulb in my gear indicator housing2004 HVAC bulbs: 1 burnt out, 1 missing. Used tiny LED bulbs in wedge sockets that I hot-glued in place and soldered to the board. Each bulb has 3 LED chips.
Red heat shrink on end of each bulb to reduce light output. I used these same bulbs in my former 2001. They were a bit too bright, but not enough to take it apart again.
Thanks for reminding me! I need to replace/upgrade that bulb as well!I did the same but i put a blue 168 bulb in my gear indicator housing
Are you changing out the thermostat and coolant lines too?The balance of the order has been received: t-belt and tensioner, water pump, 2 cam bearings, 1 front crank seal.
I replaced the t-stat several months ago to get more heat inside the cab. Not sure if I'll put in a colder one or not as it does not overheat no matter how many beans I give it.Are you changing out the thermostat and coolant lines too?
Pull the vacuum hose from the booster and plug the hose. Start the engine. Does it suddenly run better? If so, the booster may have issues; if not, I'd suspect the hose or some other device.I've been tracking down a vacuum leak. I think it's coming from the brake power booster. It's bad when cold, but after the engine warms up, the brake pedal feels firm.
Besides that I ordered AC torsion bars, manual locking hubs, redoing my diy alignment, and adjusting my steering play this weekend.
Don't know if you're aware, the preload adjuster and lock nut on the steering box are left handed threads. The job went a lot easier for me once I realized that, lol.I've been tracking down a vacuum leak. I think it's coming from the brake power booster. It's bad when cold, but after the engine warms up, the brake pedal feels firm.
That's good. We recently took our other car to the junkyard because of a P0420 and overheating problem. My better half took it to a shop for a timing belt and water pump job on it (this was when we did not live together), but it still ended up overheating after sometime. Their work order didn't mention anything about the thermostat. At first I thought that the bad cat was making it overheat. Well, the day we turned it on to take it to the junkyard, we realized the cat was gone. It still overheated on the way there. I'm thinking it was the thermostat. Would've been an easy fix, but with the bad cat and the fact that it had 278K miles, it was time to put the car down. Pour one out for Jr.I replaced the t-stat several months ago to get more heat inside the cab. Not sure if I'll put in a colder one or not as it does not overheat no matter how many beans I give it.
Yes, heater hoses, vacuum hoses — everything rubber that I can access — is on the list. When I did the t-belt in my 2001 it got as many hoses as I could reach and a new t-stat. Now I have a 2004.
I will try that out. When I start, RPM stays at about 2k for a sec and then goes down to normal idle after some time. When I step on the brake pedal, I hear air escaping with a cold engine. I can still hear it, but it isn't as severe when the engine warms up. I recently replaced the hose, but I think I got the wrong size. I could not find any sizing information so I got what looked like the right size. I ordered an OEM line with a built in check valve from z1 so we shall see if that fixes it. If not, a new master cylinder it is.Pull the vacuum hose from the booster and plug the hose. Start the engine. Does it suddenly run better? If so, the booster may have issues; if not, I'd suspect the hose or some other device.
Thank you for the tip. There was only one video I found on the adjustment of nissan frontier steering box. Man it was confusing. The audio and video said one thing, but then he overlayed text that said the opposite. My brain shut down and I decided I would just figure it out this weekend 😂Don't know if you're aware, the preload adjuster and lock nut on the steering box are left handed threads. The job went a lot easier for me once I realized that, lol.
