So I'm getting the error code P0328 consistently and have tested knock sensor wiring and it is all good which means I will need to replace the knock sensor itself eventually. Knowing that I'll need to remove the intake manifold and other parts around the engine what else should I replace/check while things are apart? Figured the valve cover and plenum gaskets are worthwhile but what other components would you tackle while in there?
2004 XE MT 3.3L - 147K
