21 - 27 of 27 Posts
Where are you located? I have a receipt for a transmission rebuild the previous owner did. The shop is in Southern California.
Discussion Starter #22
Thanks
I’m in Yew York
They’re lots of of good shops around
The only reason I use this guy is because he’s a family member
Didn’t think he was going to give me a issue
And the reason I got the transmission rebuild was so I wouldn’t have a issue
Go figure
Discussion Starter #23
So
Finally the transmission is working
not 100% but at less is working
I think if anyone that consider doing this kind of upgrade should do it on a manual transmission
The clutch upgrade will be cheaper then a rebuilt automatic transmission
I don’t know if the guys did a good job rebuilding my transmission
If feels like it’s slipping
Like the engine is too much for it
I’ll find out soon enough
When I blow it to kingdom come
I just hope it holds up for the tuning to see some HP numbers
Discussion Starter #25
What are you using to tune this thing? What planning a build like this for my S13
I’m going to rely on the guy’s from the tuning shop
Hope it’s not going to be to much money
and doable
Having a few issues with the front suspension waiting for lower control arms so can be replace
The truck it’s quick so it needs to be 100% on the suspension First
76287
new set of brakes when in also with shock
but the suspension is shit
I ran some cheap KYBs back before I knew anything.. Id look at the Bilstein 5100s or whatnot that can support a little bit of lift if you ever decide to go that route.. Might be a bit better quality as well..
Discussion Starter #27
Got the upper swing arm from 4x4Parts.com
waiting for the lower control arm bolts because the old ones need to cut to remove them
21 - 27 of 27 Posts
