Anyone have a source for the upper intake manifold bolts (plenum) other than the dealership? Two heads stripped out now I have to drill them out and find replacements.
The heads stripped out removing them. Take it easy.If you stripped them out, it's likely not just the bolts that need replaced... Steel is harder than aluminum. The threads on the lower manifold are probably fucked.
A torque wrench is an invaluable tool if you want to be a backyard mechanic. Get one ASAP.
