Hello all,
I am a newbie to the forum. I recently purchased a 2000 Nissan Xterra with about 178,000 miles on it from a guy. Originally he told me that it was in need of an alternator and had a power steering leak. Those issues have been addressed. However, there are other issues I am noticing that I need some help/guidance on which direction i should take. About two weeks after purchasing and replacing the alternator, I noticed that upon startup it blows out this whiteish color smoke for about 5 seconds max. Immeadiately after, there is a smell of fuel from the tailpipe and then sometimes itll go into this burning rubber smell. When i bought it to the shop, they suggested a tune up, in which I changed the spark plugs and wires. However, its still doing the same thing. it is also idling high with surging at idle. In addition there is this whistling sound i hear from the engine. Now im aware that none of these issues may be related. However, I just need to put it out there just in case they are. I just need some guidance on what to do next as i believe this truck does have alot of life left in it. its just that im learning that the previous owner neglected it. I do know that the valve cover gaskets need replacing. but i dont know if that would be the cause of smoke coming from tailpipe. Also it is not losing coolant. And i changed the pcv valve as well. I also cleaned the throttle body and sprayed inside the plenum where it seemed like lots of dirt and oil were coming out of when i was cleaning it. Thanks for any suggestions u may have as i plan on keeping her until the wheels fall off and when they do, ill replace them with more. lol
