Hello, my 2003 Xterra won't shift in to drive while hot. Shifts fine while cold. Changed transmission filter still same. Can anyone tell me what is going on? Is my transmission toast?
You changed the filter, does that mean you changed the fluid too? A complete fluid flush and fill will refresh the fluid in the torque convertor too and that can make all the difference. It's probably $100 in fluid but it's cheaper than a mechanical teardown if it gets you back to normal shift engagement.Hello, my 2003 Xterra won't shift in to drive while hot. Shifts fine while cold. Changed transmission filter still same. Can anyone tell me what is going on? Is my transmission toast?
Ya I changed the fluid when I took off plate. To access filter. Cleaned pan and refilled with new fluid.
Just changing the fluid in the pan is not enough, especially if the original fluid has a lot of miles on it.
The torque converter has a lot of fluid inside it and only a complete flush will clean that out.
You mention it won't shift into drive when hot.
Have you tried starting off in L1 and upshift manually?
If you are able to take off in L1 and upshift from there then it could be a problem with the electronically controlled solenoids.
If the problem persists only a diagnostic by a shop will tell you the precise problem.
Good luck.OK thank you I will do a full drain. I can drive in any gear when hot. Except drive. Thank you for all the excellent info.
If the fluid wasn’t changed as often as it was supposed to be then the trans is shot and will need a rebuild. The only way you can tell is to be the one who baught it new, if it’s been neglected then when you flush it you remove the fine metal flakes that’s allowing it to grab on the drum inside the transmission, once this happens it’s just gonna keep slipping. When it’s cold fluid is thicker than once it’s at 195 degrees. This is a issue with any automatic transmission, doesn’t matter what vehicle.basically if it wasn’t done every 35k miles it should be left alone to prevent this from happening.Hello, my 2003 Xterra won't shift in to drive while hot. Shifts fine while cold. Changed transmission filter still same. Can anyone tell me what is going on? Is my transmission toast?
Sorry, but I have to call out this myth.If the fluid wasn’t changed as often as it was supposed to be then the trans is shot and will need a rebuild. The only way you can tell is to be the one who baught it new, if it’s been neglected then when you flush it you remove the fine metal flakes that’s allowing it to grab on the drum inside the transmission, once this happens it’s just gonna keep slipping. When it’s cold fluid is thicker than once it’s at 195 degrees. This is a issue with any automatic transmission, doesn’t matter what vehicle.basically if it wasn’t done every 35k miles it should be left alone to prevent this from happening.
Spot on right there with the transmission fluid. The chemistry of the fluid is extremely important to performance! I've done full flush transmission fluid changes that have totally fixed poor shifting issues in automatics.Sorry, but I have to call out this myth.
The transmission uses clutches and metals to shift. When the trans is new, it has absolutely clean fluid and it works perfectly. As it ages, flakes get into the fluid, which is filtered to help keep it as clean as possible. Otherwise, those flakes could collect in places and cause issues, much the same as having a heart attack.
The trans was not designed to use flakes to shift. They do not help, but instead are more like sandpaper and just make things worse.
It is never a bad idea to change the fluid. There is more to the fluid than just the oil. There are detergents, anti-corrosion agents, viscosity enhancers, etc. Those all wear out as it gets older. Changing the fluid restores their strength and helps the transmission to work better.
NOT changing the fluid is not a good idea. Ever.
