I have an xterra 2001 186K miles V6 automatic. After the truck has been sitting overnight or for a number of hours there is a long lag between when I shift into drive and when the transmission engages. It takes upwards of a full minute to engage. In reverse it will engage immediately. This lag started about a year ago but was only a few seconds, now it has deteriorated. After it engages it will drive fine for the rest of the day. I found out if I shifted to low it will engage sooner with only a couple of seconds lag. Any similar experience or suggestions.
What is the condition and level of your fluid
Darin
01 Xterra SE 4x4
COMING SOON:
Wish list:
Same issue same year and 2wd. Any real solution here? Ive done fluid and filter and the problems worsened.
its likely low or dirty fluid or a clogged filter, with that age and mileage it could be normal wear to shift solenoids failing to worn/dirty fluid to clogged filter
