1 - 2 of 2 Posts
After a three inch lift on my 02 the transfer case shifter sinks in quite a bit, is there an easy fix to this?
When I did my Rancho Lift I could Barely get it to go into 4Low, theres a plate below your shifter under the truck that has a tab on it, the one that you have to push the shifter down to go between 4hi and 4low. I removed it and ground it down a bit until it worked perfectly again. if you go down there and have someone up top move the shifter mechanism you will see what Im talking about. if this is the same issue you are having I hope this helps.
1 - 2 of 2 Posts
