1 - 2 of 2 Posts
From what I have searched looks like the in port on the transmission cooler is the passenger side and the fluid return line is the driver side back to the dirvers side banjo on the tranny. Found a cheap cooler on amazon for 35$ Hayden 677 it's 52$ off right now.
I will try and do a short video of the swap when I get the 2000 3.3 auto Xterra Xe/Ls running again, going to troubleshoot distributor via ( DIY Dizzy rebuild for $7.36 ) look at my grounds maybe run a aux ground from the battery closer to the rear driver compartment then planning on going ahead with the Autozone lifetime Dizzy fix if all those afore mentioned measures do not produce a decent result.
1 - 2 of 2 Posts
