1 - 9 of 9 Posts
Newbie to towing and need some advice. 2001 Xterra. Ownswers manual says it can pull 5000lbs. Looking to buy a camper with dry weight of 3990lbs. Any advice on if I should pull it being that close to the max towing capacity.
Discussion Starter #4
Good point. I will check on that. Pretty sure it has brakes because it is a double axel. Pulling that weight yo mountains would be okay too? I know it will be slow going but better to ask folks that know a bit more than me.
Remember dry weight is 3900 lb i can easily see another 2000 lb ,4 people ,water, food, gear, full tank of gas,etc.I would not want to drive very far with that load.
3900lbs plus whatever or whoever else is inside another 1000lbs that's too much. Not good Xterras ain't made for that. I have a 12ft 5people small camper 2500lbs and I can feel the weight.
I have a 2001 and the specs say it can to 5000 lb. So I loaded my RV trailer with all I wanted to take and went to the local steel recycler (wrecker) and wieghed the trailer . it came in at 5250 lb
. So I have to lighten my load but it handled fine. I will say that I had an extra leaf added to my rear springs before doing so. Not sure if that made a difference but it seemed workable. So I will tow only under 5000 but with confidence.
I will add that my trailer has electric brakes.
So I have added a leaf in the rear springs and will be adding a weight distribution hitch with sway bar to my rig and reducing the load on the trailer below 5000 lbs but I would be interested if anyone has had problems towing with a first gen at the 5000lb limit.
1 - 9 of 9 Posts
