So it's going to be slow-going, but here's my build! I'm starting off with the easy (cheap) things for my Stage 1, while my Stage 2 is a more "complete" off road machine build, and my Stage 3 is most-likely going to be a "here's what I'd do if I won the lottery" kind of list...but who knows, maybe I'll get to Stage 3 someday. We all had to start somewhere, right?
I decided to mark my "to do" list below with S1, S2, or S3 depending on what stage I hope to perform the mod.
The breakdown:
Stage 1: This includes things I've already done, things I've already bought and are waiting to be put on, and things I plan to do in the following calendar year.
Stage 2: This includes things I plan on doing within the next 2 calendar years. Stage 2 will probably be my final stage, unless my wallet grants me the privilege to do more.
Stage 3: If I make it to Stage 3,
this list is my final build stage. Once these items are completed, I'll call my build DONE.
2004 XE/SE
Silver Lightning
3.3L N/A 4x4
70,XXX
X Stickers
(As needed)
X Lights
(As needed)
X Recovery Equipment
(As needed)
X Remove mudflaps
(S1)
X Remove rear sway bar
(S1)
X Remove rails
(S1)
_ Alternator
(S1, S2, S3, as needed)
X Idler Arm Brace
(S1)
X Remove intake baffles
(S1)
_ Cherry Bomb Turbo muffler
(S1/S2/S3, no rush)
X Paint headlight bezels/grille
(S1)
_ Replace head unit, speakers, sub, amp.
(S1/S2/S3, no rush)
|____X Head unit install done, have speakers but need to find adapter rings
X PML
(S1)
X Horn
(S1)
X Lobo rack
(S1/S2/S3)
X Shocks
(S1)
X Bedline lower body
(S1)
X Tires
(S1/S2/S3 as needed)
X Hood rod mod
(S1/S2)
_ More lights
(S2)
X Black 15" steelies
(S1/S2/S3 no rush)
_ Power inverter
(S2/S3)
_ On-board-air
(S2/S3)
_ 2" BL
(S2/S3, still not sure if I want a BL)
_ DIY Limb risers
(S2/S3)
_ 3" SL
(S3, but oh so close to buying UCAs right now)
_ Sliders
(S3)
_ Skids
(S3)
_ SAS
(S3 and pretty unlikely)
X CB
(S1)
_ Snorkel
(S3, Parts purchased, project in motion)
_ Electric fan conversion
_ Shrockworks/ARB/custom bumpers, front and rear
(S3)
_ Gobi rack/ladder combo
(S3)
X Etc...
(Never-ending...)
On to the photos:
Here's my X the day I brought it home. Not a ton has changed, as you'll see.
New exhaust put on a week later, it failed inspection so I had the work done for free. The guys ended up hanging it a little higher than stock, so the tip is barely visible from behind the bumper.
Put together my "essentials", I've since added a few more things but here's a good representation. Tools, ropes, straps, hooks, jumper cables, etc. are housed by the mortar tins.
Installed 5 Vision X driving lights, 3 up front and 2 in the back. 100W each!
In action:
Maglite mounted
Facelift time!
I really kind of like how the headlights look without bezels; except for the big gaps around the edges.
A closeup of the sun (and chemical??) damage to the grille.
First coat of paint on the grille, Krylon Fusion hammered silver.
Finished grille, two-toned it with the Krylon Fusion and Rustoleum bedliner (love that stuff).
Center lower valance
Bezels hanging to dry. Anyone lose a Ford hubcap?
Removed the rear sway bar, used some "unconventional" methods but got the job done.
