The Tale of Terra - my buildthread
10343 Views 42 Replies 20 Participants Last post by  NoWhining
29
2000 XE 3.3L 4x4; sport and utility packages
Purchased: September 1999
Modifications
Performance:
K&N CAI w/ drycharger prefilter - cannibalized and wedded to kn&n Apollo to navara snorkel
Gibson Catback - replaced w/flowmaster super 44 oct '12
Doug Thorley long tube headers w/CELs
Resonator delete
SC Radiator swap
NGK iridium plugs
Seafoam
Royal Purple 5-30w
Amsoil Severe Gear front and rear diff
Amsoil manual gear oil
Amsoil ATF transfer case
Interior:
Cobra 75 WXT CB
Clarion double DIN head unit w/bluetooth and USB iPod interface
Corbeau XRS baja front seats
OEM neoprene covers rear
Hockey stick/duct tape fly rod rack
Tools/Recovery Gear:
Powertank
Impact wrench
Air wratchet
misc wrenches and sockets
Smittybuilt strap
Bubba Rope
Shovel
HiLift Jack
Fire extinguisher
First aid kit
Fiskars hatchet
Machete
Suspension/Steering:
AC 3" SL
- UCAs, Sway-away HD torsion bars, three-leaf AAL, Bilsteins
1" BL
Total chaos steering system (centerlink, pitman arm, IA and heim joints)
Rear sway bar delete
Energy Suspension front sway bar rehab kit
Exterior:
295-70-17 trail grapplers
Eagle Alloy series 063 (4.47" backset)
warn manual locking hubs
sliders by KUMA
fender cutting/trimming
custom tube pre-runner bumper
light truss-clamp roof-rail hilift jack mount (Drake mount)
quickfist shovel mount
fold-down CB antenna
PIAA plasma ion fogs
Skid row skids - full coverage
Custom tube rear bumper
Swing-away spare tire mount
B&M Lightbars light basket
4" PIAA superwhites
Drivetrain:
ARB Rear locker, actuated by Powertank
Tx-10 transfer case with calmini crawler gears (not yet installed)
Eventually:
cargo tool box
SAS
flux capacitor
The Narrative:
So here's the story of Terra, my 2000 XE I bought brand new back in September of 1999:
Terra replaced my modded 87 4runner, totalled by a drunk driver. Currently, she is approaching 170k miles, and over the course of her life has been daily driven by first me, then my daughter, then my son, and then back to me a couple of years ago. That's when the mod bug bit. I don't have any old stock pics handy, but here's what she looked like when the only things I had done were bedliner on the wheels, step rails and roof rack, and a K&N cold air intake (before I knew better, I have since added a drycharger pre-filter to prevent dust, mud and water incursion, which might very well reduce the benefits of clean air intake, I'm not sure):
Earlier this year, a buddy and I headed North to go fly fishing on the Chama River in northern NM. There is a dirt road north of Cuba, NM, which is normally no big deal but a Class A bee-yatch if it's been raining. It had been raining. I knew from prior experience in both the 4-runner and Terra in her younger days it was going to be hair-raising but do-able. Long story short, it was a bad time to find out my POS automatic hubs were fried. No 4wd.
:traurig-big:
Took us four hours to get out, after airing down and working our asses off.
Did I mention I had put a crappy safari bar on to hold my hellas? That was before I discovered it's stupid. More on that later...
An aside, we didn't get to our destination, but did manage to hit a stream in the Jemez mountains with no name, where I salvaged the fishing aspect of the trip with a single, relatively pure strain Rio Grande cutthroat. Anyway...
Upon returning, the first thing I did was call around and find some warn manual hubs. Installed. Then decided why quit there? mod fever ensues...
Did some reading, decided I needed to lift Terra. Measured garage. Figured out I couldn't do the SL and the BL and still have her sleep indoors. Did some more reading. Installed SL...
you can also see the warn hubs. Lift finished: (sorry for crappy iphone pic)
More research, ordered wheels (17" eagle alloys) and tires (295 70r17 Nitto Trail Grapplers) Put them on ...
...and CAREFULLY drove down to my buddy's garage/shop to do some trimmin'
Took 2" off the front behind the wheel by cutting out a pie-shaped slice in front of the pinch weld, pushing it back, a little gentle edge massage, welded it back together, sprayed some bedliner over it to make it purty...
And then sprayed the outside part of the fender where the mudguard used to be with bedliner.
Cut off a pretty good part of the front fender, then sent it to my buddy at the body shop for a facial (paint front bumper and restore headlights). Also yanked the step rails.
At this point, it was decided to make that muddy road pay for what it had done to us, so back we went...
Great success!
Here's my infamous duct tape/hockey stick fly rod rack, above:
You can see at the top edge of the pic the other part of the fly rod rack is kayak cargo brackets with an elastic band that holds the end of the fly rod behind the reel, the foam rubber with the holes holds the rod itself. 9' rods fit nicely, just short of the windshield.
I wired up Hellas and attached them to the safari bar:
Safari bar and Hellas came off when I found some time to get started on a real front bumper
Before the new bumper build, went wheelin'!
...and got dirty:
Another round of mods included rolling the rear fenders to prevent bad things happening at full stuff:
And then a 1" BL to make sure (took the 2" DIY BL bolts, cut the pucks in half and then used the discards for spacers so I could use the same bolts)
then it got serious. Custom tube front bumper:
rear tube bumper:
swing-away spare tire carrier:
(and CB antenna remount)
B&M Lightbars light basket and 4 PIAA 4" superwhites:
Total Chaos King Kong Steering:
Powertank:
1 - 20 of 43 Posts
Nice writeup and I'm glad that you're getting more into the forum!!
Thanks! Your X kicks a** too, loved your build thread
Awesome X... and a great story to go with it!
Any chance you could add some more pics of your trimming job up front. Sounds like you put a lot more thought into it that the standard 'BFH to wheel well' approach.
unfortunately I wasnt thinking about a step-by-step when we did it, so not much in the way of pics. Started on the passenger's side with an angle grinder and cutoff wheel. We weren't sure how much we needed to cut, so it was a little bit at a time process. Eventually we determined that to fit these particular wheels and tires, (backset 4.5") we would need to move the edge of the fender closest to the tire back 2". But, again, that happened a little bit at a time, putting the wheel on, checking it, taking it off again, repeat, etc. But...
Once we got that side done, the driver's side was a (relative) piece of cake. Pulled the plastic mudguard off, measured two inches back from the bottom of the fender and marked it. Used the AG to cut out a pie-shaped wedge, basically eye-balling a line on the back (rearward) side of the cut from the bottom of the fender diagonally toward the top of the wheel well to try and keep a straight/clean line into the curve of the well. The edge of the cut further away from the wheel buts right up against the pinch weld. Once you make the cut (and there's a fair bit of metal to get through), pull out the pie-slice shaped wedge, then you work on closing the gap you just created with the "pie cut" and pushing back away from the wheel. Get it tight and massage it so the pie shaped gap is now a seam, using a hammer, pliers, wire wheel on the AG, whatever is handy to get it reasonably uniform, weld it up, then fold the edges in as shown in the "it's done" picture.
Hope that helps...
I LOVE Nitto Trail Grapplers but don't see many people running them so I never get to ask, how do you like them?
So far, great. They're pretty quiet for how aggressive they are. Can't comment on durability yet. They were champs in the mud, too.
The only complaint so far is my soon-to-be-ex-friend at Discount Tire didn't ask me which side of the tires I wanted facing out, and he picked wrong...
Nice write up! I love fishing too. Are those brown trouts? I took these year off from trout fishing and been concentrating more on the steelheads and salmons. I thought about doing the same as you and building a rod holder inside my X but I decided it was easier to just use my snowboard rack carrier on my roof. Your X looks good. Did you re-gear to run those 295's?
Yup. those are browns!
I did not regear - probably about the biggest you can go without needing to.
Welcome to CX
Thanks man! Love your X. The mountains are genius!
One other mod I forgot to mention: over the past few years I had several cooling system hose failures. After the last one I replaced all remaining hoses and swapped the puny original radiator with the bigger one. Makes a big difference and the engine runs at the same temp now regardless of conditions. Highly recommend.
Nice build man... which radiator did you go with? I have my radiator pulled right now while I'm having the motor heads rebuilt at a shop in Burque. I figured I would do an almost complete restoration under the hood while I have the engine torn apart and that radiator does look pretty scrawny.
Also, as soon as I get the weight of the heads, battery, radiator, cats and intake/exhaust manifolds back in the X, I will put on a set of 33" x 12.5's (no body lift for now) and trim as much as I can from the front fenders. I'm planning on removing at least a couple of inches near the front doors, then weld patches and fabricate sheet metal "caps" to cover the irregular fender surfaces exposed by removing the fender plastic. I'll probably cover everything with bed liner as you did. Something tells me that I will still have to install BL pucks but I also suspect that a perfect balance between wheel backspacing, tire size/profile, and trimming may get us to where we want to be without a BL. I have a set of 1" BL pucks on hand just in case.
I admire your persistence when it comes to avoiding a BL; I too am determined to find a better way if it exists. Maybe our X's will cross paths out on the Chama next spring...
Rokwel
Rokwel
I can't remember the brand right now, I can find out I've got the receipt somewhere. What I can tell you is it is substantially thicker than the original, 2" as opposed to the puny original which I think was less than an inch. I'll post a pic and find out in the near future. Right now it's too damn cold!
:frozen-big:
Also I think I'm going to have to go with the 1" BL too. We'll see...
I have never looked at your build but I found it by googling muddy xterra pictures, I really like the X!!
Thanks Man!
i can dig it.
10
So I've been neglecting this thread for a while...here's where Terra is today:
Terra
Modifications
Performance:
Gibson Catback
Resonator delete
SC Radiator swap
NGK iridium plugs
Seafoam
Royal Purple 5-30w
Interior:
Cobra 75 WXT CB
OEM neoprene seat covers
Tools / recovery gear / air compressor
AC 3" SL
- UCAs, HD torsion bars, AAL, Bilsteins
1" BL
IAB
HD TRAs
Exterior:
sliders by KUMA
Skid row skids
In the works:
Rear tube bumper
spare tire mount
light basket (under construction at B&M Lightbar headquarters)
4" PIAA superwhites for light basket (here and waiting to be mounted)
Eventually:
snorkel / including CAI enclosure
cargo tool box
flux capacitor
Tube bumper with PIAA fogs:
KUMA sliders (after 1" BL):
Truss-clamp Hilift mount (The Drake Mount)
Cobra 75WXT with fold-down antenna:
Quickfist shovel mount:
Posin' and wheelin' (before the 1" BL, tube bumper and sliders):
Sunday afternoon wheeling...
Bump for update on OP
1 - 20 of 43 Posts
