1 - 2 of 2 Posts
Got an '05 Xterra SE with the Rockford Fosgate system, but just put in a new Kenwood x692 head unit. The place told me the sub underneath the seat would still work just as well (it would literally shake the car), but I just picked it up and got nothing.
Can you not use that sub mounted underneath the seat anymore if you aren't using the factory stereo?
If you have gotten this to work, what's the work-around?
im not to familiar with that stereo model in the 05 but i would try to find out which wire is the remote wire (sends signal to turn on the amp) and make sure it working properly or check if the line tap or RCA's are in working order (i dont know which one it uses)
1 - 2 of 2 Posts
