Shocks front and back, and yeah, very easy swap.
If you want to improve performance off road, you need longer REAR than stock shocks.
The front ones are long enough as is, because its IFS, and the arms just travel up/down between the upper and lower bumpstops, no matter what...essentially the same travel. (Unless you also go to certain aftermarket UCA, etc...)
Shock Warehouse
http://www.shockwarehouse.com/?utm_...banner+link&utm_campaign=SW+-+Forums+-+Banner
Gives us a discount on shocks...so you can try there.
www.4x4parts.com
also has a good selection.
These are good sources, because most of the places just have OEM sizes, and if you want something else, YOU have to tell THEM what part # to send you instead, etc....or take pot luck, etc.
BTW - to the guy who paid ~ $500 for 4 shocks:
:laugh-big:
Thats $125/shock....holy moley, for NAPA?
That's about
double what a GOOD set of shocks can be had for.
Hmmmm, its probably $100 worth of shocks, plus labor at $800/hr?
:wink-big:
Seriously...easy job, taking the front tires off helps...but its a few minutes per shock, one bolt at each end essentially.
The fronts have threaded posts on the tops, and eyes on the bottom.
The rears are double eyed.
Also - To make sure you know -
If you get the Bilstein HD or 5100's for the 3" lift kits...they FIT A STOCK X WITH NO LIFT TOO.
IE: You get the wheel travel of the 3" SL, at stock height, with no downside.
That way, if you DO get a lift one day, you do NOT need shaocks for it, you already HAVE them.
:wink-big:
