1 - 1 of 1 Posts
I'm new to xTerra platform and clearly understand that some folks here have earned their PhD by now but either due to my search capabilities or availability of the appropriate material I couldn't find much on a few things I came across of that I'd like to mention.
I've had positive experience with Rough Country products before on a different platform and by far couldn't say anything bad about the company so I figured I might as well stick with what I know when it came to chose a lift kit for my 06. Aside form being a fairly inexpensive kit it looked well done to my eye and I'm happy with it by far. Nonetheless, there were a few things I wanted to address ...
1. I'm hoping I'm wrong, but the nuts used to attach a spacer to the top of the strut assembly looked somewhat thin to me.
2. In the same group, I had to throw away the lock washers used to attach the above spacer to the top of the strut because the strut bolts are not long enough to accommodate a washer, a lock washer, and a nut on to of all of that. I had to Locktite all of them.
3. While going by the installation video posted by RC on Youtube, I obviously wasn't expecting that easy of a process though I really can't complain ... it took me only 5 hours to install it all. The one thing I had to do is to use weight of 4 people standing on the side step to compress the strut assembly so I can mount hub onto the upper ball joint ... it would lift the entire vehicle when I was trying to use a floor jack under the lower arm.
4. Lower control arm adjustable bolts - it is listed as a "recommended accessory" ... buy it and install it while the entire front is disassembled ... much easier than come to a shop for wheel alignment only to find out that they can't do anything because you have regular bolts and to install those you forgot/bought later would cost you another $300-$500.
Other than that ... thanks a ton to Rough Country for a great shopping experience.
I hope it helps.
1 - 1 of 1 Posts
