1 - 4 of 4 Posts
:) Hello everyone! i need some help with my roof rack. I have a 2013 Xterra S. I was in the process of installing a lightbar from offroadgorilla and the two bolts on the sides up frontward of the rack are what i need to remove. but on both sides the 2nd bolt keeps spinning! the seal didn't break nor is it stripped but i found out that the anchor that the bolt is connected to where the threads lock together broke off is just spinning with the bolt. Does anyone know how to actually pinch the anchor and free the bolt? :eek:
thanks for everyones help!:nerd:
I'm kinda wacko
Yep, you'll need to pull the headliner to get to the inserts, to hold them while you remove the bolts. It happened to me when I did my body color change as well.
1 - 4 of 4 Posts
