well the bolt patern on our trucks is 6 lugs on a 5.5 circle. if you are getting the rimes just for winter looks shouldnt be an issue you can find those cheep black steel rims. like the ones for hubcaps. or here is the nissan oem steel rim
http://market.autopartsfair.com/nissan-wheels_rims/xterra-2004-oem_steel_wheel_rims-stl62368u20.html
the only difference is the rim size which will give you more sidewall and tires will be a bit cheaper
i hope this helps.
i hope this helps.
