So now that my 2 inch body lift and PML is complete, I need to order wheels and tires. I was originally going to put 33x12.5 on the X with stock rims which I believe are 5.5 inch back space. I test mounted one at a tire shop and found with the 5.5 backspace it rubs a bit when the wheel is at full turn on the bracket on the frame that protects the fuel lines.
I decided I want to get away from the stock wheel look and I am looking at 33x12.5 inch wranger duratracs and I want to mount them on 15 x 8 wheels with 4.5 inch back space. That should pull the wheels away from the frame a bit correct? Will 4.5 inch backspace require any metal trimming, im not worried about plastic. What about 3.75? Thanks for the help guys.
