Is there a write up/schematic for these or does anyone know where i can get part numbers?
I'm finding a lot of parts for Frontiers that are Xterra compatible. Did they use the same power plant for awhile?
There are 4 total; 2 on each side, in front of and behind the cats. They plug in on top of the passenger valve cover.
The Frontier and Xterra are very close sisters and the motor isn't the only thing they share.
Depending what sensor(s) you're replacing, you may want an O2 sensor socket. Or you may be able to use a box end wrench.
As far as part numbers, those will come from manufacturers like Bosch and NGK (which is something like NTK for O2 sensors). You can just look them up on their websites, or go to Autozone's/Orielly's website and search.
