2002 non supercharged, 4wd 5speed, & not sport edition.
Possibly helpful background info
Two oil changes ago I had a K&N air filter installed because a friend recommended it. I have no cleaned it since and am on the verge of my third oil change (horrible). Few days ago the CEL came on as I drove up a steep hill at about 3k RPMs with no extra load & not pulling anything.
CEL on and tested at autozone
PO328, PO430. Knock & O2 sensor, if I'm reading report right.
Ok. Should I get more specifics on which O2 sensor(s) and replace? Is there a way to test the sensor? Or is it possible that all of this is because the air filter might be horribly dirty? (From other threads I understand I do not need to replace knock sensor)
Thanks
*Edit- After undoing the four latches holding the K&N air filter, do I need to undo the four bolts keeping the filter top/cap attached to the air flow piping? - I don't know the appropriate jargon.
Thanks
