First time poster, long time reader.
I own at 2002 xterra 4x4 and i recently bought a new set of wheels and tires for it that came off a 2015 Titan from factory. Tires and wheels are in great shape but when i went to replace the front two wheels they would not fit. The center bore was way too big for the new wheel.
My question is, are there any ways to solve this? i'm not a fan of boring out the new wheel to make it fit, sounds like a structural integrity problem after that.
Is there a spacer big enough to make it work, or is there a smaller hub that i can replace it with?
Thanks for any help
nope, boring is your only option and even then you have to go all the way through to clear the front hub. Its easier if you had a 2wd but on 4wd forget it.
