Drivers side. I drive mostly on the highway, and I read about people removing them. Will it be squirrley if I remove it completely? I mean it's kinda squirrley now, could that be why?
Take it the rest of the way off. Mine's been gone 3 years no difference at highway speed (up to 110 kilometers). Like said above check your shocks. Granted it doesn't handle like my civic, but I'd (and a lot of engineers) be shocked if it did.
if your mount is broken...the sway bar isn't doing the job anyway. Taking it off should have zero change.
Rear sway bar makes no real difference regardless. Maybe at fast highway speeds on 180 or 270 degree off ramps, you may notice more sway slightly, but it is really a subconscious adjustment, if that.
Check the link in my signature for how to remove. DEFINITELY not worth fixing or replacing.
Well that solves that, thanks! 127k on the front shocks, and about 25k on some cheap rears may be why it wobbles. Off to research shocks. Thanks for the input.
