1 - 2 of 2 Posts
Hey guys I have a question that I hope I am putting in the right place. I have 2 Dana 44 axles one front one rear that I got from a junk yard as a pair. And I have them for an eventual solid axle swap, but that is for another time when I have a bit more money and have finished fixing up those axles. I am in the process of doing a 3 in suspension lift (by process I mean I am buying it a piece at a time) I was wondering if there was any reason I could not go ahead and restore the Dana 44 rear axle and slide it under there while I was at it? You know for a stronger axle with more locker options.
2000 Xterra XE 4x4 3.3L AT
Other than the width of the axle probably not. The only real reason to switch out the rear though would be for a cheaper locker option and to match the width on the SAS front unit. The H233B rear in these trucks is a 33 spline unit and a notoriously durable rear end. The reason to replace were the locker options and cost of gearing but the gearing costs have come down.
1 - 2 of 2 Posts
