1 - 4 of 4 Posts
Hey Guys,
I am finding that with my fully loaded bike rack and truck full of guys to go mtn biking that my rear suspension is really sacked out. Especially when we are driving up mtn roads. Is there something that I can do to beef up my rear suspension at all? Add a leaf? Has anyone done anything like this?
Thank you!
Upgrading your shocks is not going to do the trick.
Your best bet is an Add-A-Leaf or if you want to spend the money a complete spring pack.
However, if you go with an Add-A-Leaf, you are going to gain some lift in the rear. If you do not want any lift, check out the Timbren bump stops.
http://www.timbren.com/aeon-rubber-springs.htm
HI Muzikman,
How good are those timbren springs?...do you have them on your truck?.... im looking for a replacement of my rear spring set, as the leafs are fatigued, so the rear part of my truck is always low.. and im thinking on add a leaf system from calmini, or aribags from firestone, and now im looking into this timbrem stuff and i kind of like it.. just not sure if it will work with my problem at hand... or if i need both systems... any light on this will be highly appreciated.
Thanks
Roy.
1 - 4 of 4 Posts
