1 - 8 of 8 Posts
Hi. I have a 2007 xTerra. About a week ago I unlock the doors but the rear hatch door wouldn't unlock. I heard the clicking, but it wouldn't unlock so it cannot open. My key doesn't fit fully in the key slot & I don't want to force it.
I've been online checking various forums & videos about it. Right now, I'd like to get it unlocked and open. Any advice or suggestions?
I have the same issue with my 2013 sometimes. It seems to be a little finicky. The only thing I have found so far is to re-lock it using the key fob or the lock button on the driver door. Then try to unlock with the key or fob again... that seems to re-set it.
Once you do get it open, double check the latch and lock to make sure they are clean and free of any debris, hit them with compressed air. Maybe give the key lock a spritz of WD 40. Hope it helps.
My rear hatch will not open as well.
I towed the company trailer which was just rewired.
Found my rear hatch not working.
Parked at home.
The following morning my battery was dead.
Replaced the battery.
When the terminals are connected the alarm sounds ENDLESSLY.
Tried connecting battery with all doors shut and unlocked.
Turned the key twice on the drivers door and attempted again locking the rear hatch.(with the alarm sounding)
NO LUCK.
Any suggestions would really help right now. I need to get to work.
2000 3.3
I had that issue with mine, or similiar, when something got stuck in the track. I am always watching my rear hatch to make sure it is closed properly.
Is the hatch "loose" or is it tightly locked? If it is loose try bumping the hatch to see if you can get it to lock correctly, maybe while working the key in the lock?
Might also mean you need to lube that lock mechanism.
There's a good chance there's something stuck in the track.
This is a work truck and I'm constantly in and out of the back for tools.
There is NO play on the door also, it is very firmly shut.
I'm about to try to disable to anti-theft system by pulling the fuses...willing to cut wires at this point.
For a rear hatch lock that will not unlock and will not unlatch, I figured out the problem on my 2006. The return spring on the latch got weak and would not return the latch mechanism to resting position when the handle cable is relaxed. The mechanism not returning to the proper testing position blocks the lock mechanism from going to the unlocked position. I fixed this by adding a helper spring to the latch mechanism as shown below. This helps the latch mechanism always return to resting position so the lock mechanism can unlock.
Getting to the latch mechanism with the hatch locked is a bit tricky, so I will tell how I did it. Access the hatch from inside. Remove the two handle bolts, and the two small bolts behind the first aid kit. Then hook the panel through one of the handle bolt holes pulling away enough to get your fingers behind the panel and gently pull it away from the hatch, beginning at the bottom. It has a number of clip fasteners scattered across the panel, but no other screws. Once the panel is removed, remove the insulating sheet from the hatch. Then reach inside the opening on the driver’s side and find the cable that comes from the handle and push the mechanism to the resting position so the relaxed cable gets taught. (Mine actually had slack in it due to lack of spring tension.). Once you return the latch to the proper resting position, you can fully unlock the latch with the key-and open the hatch normally. Then remove the three black mounting bolts, the nut, and the lock mechanism rod. Unplug the two wire connectors, and you can remove the latch assembly. I left the cable connected when I did the modification. Add a helper spring as shown, re-assemble everything in reverse order, and you are back in business. Hopefully this is helpful because a latch assembly was over $200 from the stealer.
73613
1 - 8 of 8 Posts
