1 - 1 of 1 Posts
This might help someone...
My 2010 Xterra would not lock the rear door with the Fob or the door button, but it would unlock the rear door with the Fob or the button if you had manually locked it. The only way to lock the rear door was manually with the key.
The fix was simple. The electric mechanism that locks/unlocks the door had vibrated loose behind the panel, and while if could push the rod to unlock, it had slipped to a position where it could not pull enough to lock the door. All you need to do is tighten the mounting screws inside the door, and a little locktite will prevent the problem in the future.
1 - 1 of 1 Posts
