Interested to hear how this one turns out. Good luck.P0301 is my fault code. cylinder one misfire. to the mechanic it goes tomorrow!
Wonder if you could get enough of a hydraulic lock to cause that shake from fuel building up in #1 cylinder from a faulty injector?Ditto. For it to shake that much, one would think that there is more going on than just a misfire.
she is down at my mechanic now. they’re taking apart that upper part of my engine to do my spark plugs, spark plug tube seals, valve cover gaskets, and valve covers as well as they’re going to check on my fuel injectors! i’ll keep posting updates until she’s back running like normal.Wonder if you could get enough of a hydraulic lock to cause that shake from fuel building up in #1 cylinder from a faulty injector?
Under the knife! Hope they can control the bleeding....the green stuff that is.she is down at my mechanic now. they’re taking apart that upper part of my engine to do my spark plugs, spark plug tube seals, valve cover gaskets, and valve covers as well as they’re going to check on my fuel injectors! i’ll keep posting updates until she’s back running like normal.
totally forgot to give a final update! coil on cylinder one died and was causing the misfire! Xandra is home and safe. Runs like new and i don’t even realize she’s idling now. We did the valve cover and gasket replacement as well and i got a new vacuum hose since one of mine was so cracked it was about to start leaking! Thank you all for the help and concern expressed for my Xterra!View attachment 79787 she’s all taken apart. a singular bad coil on cylinder one. of course the hardest to get to
You are truly blessed! Thanks for following up.totally forgot to give a final update! coil on cylinder one died and was causing the misfire! Xandra is home and safe. Runs like new and i don’t even realize she’s idling now. We did the valve cover and gasket replacement as well and i got a new vacuum hose since one of mine was so cracked it was about to start leaking! Thank you all for the help and concern expressed for my Xterra!
Boy that brings back some memories!Shotgun!
(That means I get to ride up front.)
