581 - 600 of 606 Posts
Nice rig. I just finished reading through the 580 posts in this thread. Lots of good info in here.
Brooklyn br0
'01XE 4x4 3.3AT Locked SAS 35's
I feel for ya bro. Been through it a few times myself.
I found that it’s best to change everything rather than one thing at a time as they wear out. If one part of our IFS is just the slightest bit worn it takes out the other parts as it goes. What a pain.
On the side; almost every LBJ change I’ve personally witnessed has resulted in a LCA failure including one of mine. I think that’s the reason Nissan does not recommend it in the FSM.
So ya might want to change out the LCA if you can find a new or less worn one while you have it all apart.
Do not use an “aftermarket” LCA, only the Genuine Nissan part will do. Aftermarket Chinese steel does not hold up...seen that on a buddies truck. Couldn't survive the trip from NJ to Brooklyn.
2000 Xterra XE 4x4 3.3L AT
Discussion Starter · #584 ·
Well life got in the way cash got tight, very tight, and I’ve been driving it with a problem for a long time. The little shimmy I felt transmitted into everything else and did a number on all of it. But I love this truck so I gladly buy the parts and start over.
On the LBJ’s and LCA’s I was aware of that. I’ve replaced my LBJ once before didn’t want to but did it anyway and gonna have to do it again. Still financially recovering from a long spell of unemployment so when I pull the LBJ’s in the morning I’ll take a long hard look at the control arms but unless I see a crack gonna have to use them again for a little while at least. No wheeling until at least this fall so hopefully I’ll be ok.
All torn down and new assemblies built going to the race shop in the AM and press in wheel bearing races and Bandit bushings then hopefully fab up and weld up some pieces to make the pitman and idler connect to the centerlink in double shear rather than single.
Brooklyn br0
Sounds good. It seems to slow the rust/wear of the LCA if you put a bead of silicone, rtv or some kind of water proof in the gap on top of the LCA, between it, the LBJ and the LBJ nut.
Discussion Starter · #586 ·
Good tip, remember though this is the south Brother rust is rare down here. ;) I can still read factory stickers on the frame and the paint pen marks and letters from when it was assembled.
Brooklyn br0
Wow, I can’t imagine what that would be like...
Discussion Starter · #588 ·
So new inner/outer tie rod ends, lower/upper ball joints, pitman arm, idler arm w/Bandit 4x4 bushings, AC upper control arm bushings, wheel bearings and seals, and two new KM2’s on the rear and it’s no longer a death trap to drive. Two more new KM2’s in the garage after I get an alignment in a week.
New Performance Friction pads also in a week as well as windshield wiper linkage, quit today, and after a mere 10 years my Optima redtop gave up the ghost this morning, new one already installed.
This has been a busy costly week :p But I gladly replace worn out components they have to wear out at some point. ;)
Discussion Starter · #590 ·
Hey glad to see you are still around, hope you still have yours. ;)
Yeah still have it just have a laundry list of neglected items to repair.
Still have mine. Runs smooth as butter. I know what you mean about maintenance. Going to be doing a couple of things to mine this week.
03 XE A/T, SC coming soon
We have a supercharged frontier with the solid axle and 35” tires and it seems like way more trouble than it’s worth. That truck will probably be for sale soon
Discussion Starter · #596 ·
So all the front end work means the SAS is still on hold?
Yes still on hold. For what I use the truck for now SAS is way overkill. Currently it’s more of an adventure truck than a trail rig as we use it to gain access to remote areas to practice our other hobby wildlife photography. Muddy or flooded fire roads with the occasional serious obstacle so with good tires, good articulation, and the locker it easily walks through the trails we use. Still in the future just not the immediate future.
Discussion Starter · #597 ·
It seems it’s really a pain or not depending on how the SAS is executed and the quality of the design, fabrication, and components used. I’ve seen quite a few well thought out and well planned ones that are durable and trouble free but I’ve seen way more that just make me shake my head and think why. ? It seems many are done so they can just say yeah it’s SAS dig me with little to no thought on how well it will work or how durable it will be.
2000 4wd 3.3L AT
There are 2 local X's both green that have all of the bumpers and trim painted to match the body panels. Kind of like that blue Gen 1.5. One is a Gen 1 and the other a 1.5.
Do you know if this was a factory option?
