1 - 2 of 2 Posts
Some Nissans come with a Brake Booster Hose with internal/intergral Check Valve (e.g. 2000 Model 6-cyl Xterra part #47474 - see top illustration...the bulge is a check valve on the hose). Whether internal or a separate check valve, I am interested in the diameter of the hose I.D. if it is integeral or the hose barbs of the check valve if an in-line one.
http://www.courtesyparts.com/xterra-parts-wd22-2000-2004/genuine-nissan-parts/brake/470-brake-servo-servo-control/-c-532_14_76_444.html
Would someone be so kind as to identify the diameter of the hose barbs on it?
Probably a 10-13 mm.
Thank you in advance.
1 - 2 of 2 Posts
