Admittedly some car power adapters are too long to fit the socket and stay put, but that's more of a design flaw in the cheap gas station chargers. If that's the issue you're having then my solution has been to rotate the charger in the receptacle until it clicks. There are slots inside the outlet. It generally stays put after that. The receptacles do appear to be a little more shallow than on my wife's 2008 Toyota.
You could see if you can find a universal replacement that is more to your liking.
If you are talking about power then you would have to rewire the outlets with heavier wire and of course use a bigger fuse...
On amazon there are a number of 30 - 60 watt USB charging receptacles available that you you have to wire in with a fuse. They look to be swapable with your light, but you would have to do some wiring.
Just look up quick charge 3.0 USB car charger socket on amazon and you should find plenty of options.
