What up Xterra gang! lol. I need help plz! So Ive noticed that my brakes are super soft. They are able to push all the way to the floor with ease. I hear a loud hissing noise and it sounds like its coming from in the car.
I been driving it and its okay at low speeds or if I slowly brake early. If I press the brakes fast, sometimes it gives out and I have to push really hard(pretty scary at stop signs)
I checked the fluids and its maxed.
Checked under the car and all lines look dry.
I read that if you push the brakes while car is off, then start it, if the pedal depresses then the booster is good.
So my booster is probably good.
Thinking maybe I should bleed the brakes? Maybe theres air in the lines?
My brake fluid is green so its prolly best I change it anyway.
Ill try that first and if it still has the problem, is it time to change the master cylinder?
Been lookin online on when to change the cylinder but im still unsure.
Any suggestions guys??
