Stock BS and 33" overall diameter will not rub the top of the fender lip or the wheel well. The back of the fender will require cutting if you greatly change your wheel BS. The other problem that you will run into on the back is rubbing the frame & body with full articulation. 31's barely rub in back with stock wheel BS and full articulation. Mine has the rub marks. Suspension lift has no effect on tire size. What it fits stock is what it will fit lifted You could be like the Jeep guys and ruin your suspension travel with longer bumpstops.
