Ok I know this has been answered before and asked before. I would like to do a PML and a 2" lift and slaping on some wider tires. I have read alot of posts and I searched the DIY trheads and I am starting to be more confused than where I started. I have a 2004 Xterra.
sigh
OK, to clarify...the PML is a 1.5" Suspension Lift (SL)....you do it by adding longer rear shackles to lift the rear, and adjusting the torsion bars to lift the front end to match.
When you say "and a 2" Lift", I'm hoping you mean a 2" Body Lift (BL), as that is what makes ROOM for the larger tires you wanted to slap on.
A BL simply raises the truck's body higher off the frame. The truck has 10 body mounts that the body sits on, attached to the frame.
A BL simply inserts a spacer to make the body mount taller.
This raises the entire body, which, in turn, also means that your wheel wells are 2" higher as well.
The sweet part about the BL raising the wells, is that when you go over a bump, that extra 2" is still there.
With an SL, when you go over a bump, and the tire rises, it will hit what ever it would have hit WITHOUT the SL....as the extra room was only at ride height with an SL.
So, that would mean your plan was to do a PML, adding 1.5" of suspension ride height, and a 2" BL, adding 2" of extra tire room.
I didn't see an actual question, just the statement that you were confused, so, I hope that cleared things up a bit for you.
:wink-big:
