Will 16'' inch Chevy wheels fit the Xterra if they have a bolt pattern of 6x5.5, a backspace around 5.5 and a center bore of 3 inches?
I cannot grasp the idea of the center bore?
If it is bored out does it compromise the wheel?
the bore on the wheel is too small
shouldnt hurt it to bore it out if its done properly
i think the xterra's center bore is 100mm
Okay, I'm just trying to score a pair of cheap steel wheels, for some reason Craigslist is littered with Chevy rims. As long as the center bore is machined i should be all right? Tire shops will install even if it is bored out?
if they are bored out right then the tire shop wont even know the difference.... i priced this a while back and i think it was around $25 a rim...
