I recently purchased a 2002 3.3 XE with 220K Miles. I had misfire and knock sensor codes causing the vehicle to go into limp mode so the shop put in a new distributor and cleaned the MAF sensor. When leaving the shop, the car would not shift into OD. I pulled the codes when I got home and I'm getting Knock Sensor and P0744 TCC circuit intermittent. The car was well maintained. Recently had timing belt, water pump and steering pump replaced before I bought it.
My thoughts are to try the following in order and see if it clears up the problem.
1) Either flush or change the transmission fluid (thoughts on which would be better?
2) Pull off transmission pan and check for significant metal shavings
3a) If significant metal shavings then consider looking for a used transmission to have installed
3b) If reasonably clean, check/replace filter and replace TCC Solenoid. (is this a reasonable job for someone with limited car experience, but who is competent technically?)
4)Find a new transmission.
Any thoughts would be hugely appreciated as money is tight and I bought the the car only a week ago.
Thanks
Thanks
